Hi Communities,
Is there a way of increasing the available space in the a DGNlib for creating buttons?
As you can see, I have tow buttons that have been cut off. I working on AECOsim SS6.
Let me know if you need any further information.
Oliver
Check the saved view used for the screen menu most likely you just need to update the view so all the elements fit within the view.
See the online help.
Hello Oliver,
Regarding your use of Screen Menus...would you mind answering a few questions?
Regards,Dan
