Hi Anyone,
The elements (see snippet below) are modelled using standard elements from structural designer tool from AECOsim.
However, when I checked the same in this morning and it looks like surfaces and can't see the whole objects (solid).
Please any one can advise why this is happening.
Hello Balaji,
can you explain the modeling workflow in details?
Hello Sayanti,
The models are created using standard shapes (i.e slab, piers, etc.) which are available in the tool panel then made the cut solids for chamfering the edges.
Is that makes clears to you?...
Any chance you attach that DGN file for review?
When you create a clipped view, does it still show as a solid (uses for example the part definitions for fill/hatch)?
As Steve mentioned, adding the file would help.
Windows 10 pro
OpenBuildings Designer Connect Edition 2023 | 23.00.00.114
