HELLO, I Have a lots of problems with the units in my floor manager. today y load the aecosim and when i want to start modeling i realized that all my unities in my floord manager changed... i was working in mm and my ACS was Fullsize 1: 1,
when i choose a floor, all changes.. and my floors and grids go crazy...
you can see. all the units were multiplied by 1000 and my drawing Scale changed too... i cant fix it... This problem made me lost a lot of worktime... and i cant continue working till I fix it.... plese help me.
How can i verify this? Im really new and im in my first steps. can you help me?
Hi Esteban,
Sure! Check out these Wikis for both a reference to Floormaster units as well as general Solids Working Area and Working Units information:
https://communities.bentley.com/products/microstation/w/microstation__wiki/24873/microstation-connect-edition-configuration-variables#datafiles
https://communities.bentley.com/products/microstation/w/microstation__wiki/2972/using-the-solids-working-area-in-microstation-v8-cs
https://communities.bentley.com/products/microstation/w/microstation__wiki/8933/working-units-faq
