On starting work today I now have the following message appearing
Nothing has been altered or changed since shut down yesterday, same 2D dgn file is being opened
Pressing OK clears the dialog box and everything works as expected
Any ideas
Ian
Hi Ian,
Are any of the three BB_NAMING_STANDARDS_XXX configuration variables defined? If so, which dataset are you using?
Hi Steve
BB_NAMING_STANDARDS_ENABLE is undefined
BB_NAMING_STANDARDS_FILE is Workset
BB_NAMING_STANDARDS_PROJECT_ID is undefined
Dataset is Dataset_NM
The Workset file defined is …\Dataset_NM\Setting\BS1192_FilenameSetting.xml which does not exist in the directory location but the file does exist in the Dataset_UK which has not been used since ABD U4 was installed
HTH
currently using OBD 10.10.01.151
HI Ian,
BB_NAMING_STANDARDS_FILE should be undefined as well.
We don't deliver these variables in the NM WorkSet CFG. Do you know if BB_NAMING_STANDARDS_FILE has been included elsewhere?
Marc
Hi Marc
Started my PC this morning to find no UnifiedFilenaming Utility error message appearing and that the BB_NAMING_STANDARDS_FILE is now undefined.
I'll put this down to one of many strange / odd things that is happening with U4
Answer Verified By: Steve Cocchi
Odd indeed... but good to hear that it's working as expected now.
