Just referenced the border into drawing sheet and can't display logo (cell) in colour.
The same reference attached to different sheet looks ok.
Could anybody help?
Hi Tomasz,
Can you attach a screen capture of both the drawing and sheet results so we can see the difference?
Hi Steve,
Thanks for quick respond.
Please find attached test files. In both I have attached the same reference (TITLE BLOCK). One display in colour and another only B&W.
I need to change settings of display from B&W to show logo in colour.
6835.TEST FILES.zip
Tom
Thanks, that definitely did help. As it turns out there is a subtle difference in the color tables of the BW file:
vs. the Color file:
Specifically, color 253 is the Network Rail text and 254 the filled shapes.
Thanks for message.
I have changed colours 253 and 254 on colour table to suit "coloured version" file. So in both cases I have this set: It doesn't work :-/ Also I have selected "Use Colour Table" in Preferences... and still nothing.
Can that be seed file configuration issue?
I suppose that's possible, but off the top of my head I'm not sure which settings or variables might have this effect.
Just to be sure though, you are changing the color table values directly in the file TEST FILE BW.dgn, correct?
