Starting to find very odd behaviour in U4
First there was my previous post re BB_NAMING_STANDARDS_FILE which just resolved itself
Today I've had the situation when transferring between files using the all view groups visited dialog U4 decided to open the file in read only mode.
to correct this issue I'm having to transfer between files using open and with that method the file to be opens properly.
Have to simply ask why?
Ian
Hi Ian,
I've never used that particular tool before (I learned something today!) but now that I have, after navigating back and forth between three different DGN files I am not seeing what you've described. Are the DGN files stored locally or on a server? Any chance someone else could have had a file open while you were attempting to navigate back to it?
Hi Steve,
Only happened a couple of times and not since
Stand alone machine with files on a server and nobody else in office using any Bentley software
currently using OBD 10.10.01.151
Answer Verified By: Steve Cocchi
That sounds like a case of Christmas gremlins to me.
