The Connect edition Items dialog lacks the detail that v8i used to have.
See below, I want to select all columns of a certain size within my model. Items just displays a list of identical catalog types. I can use details to see the information, but this does not allow me to select them. It places a small arrow in the items list next to the item name, but you cannot select from this.
In v8i(which is how it should work, ie actually usefully), the items dialog displays as a tree, allowing you to drill down into the catalogs and items to select the correct sections/cells/catalog items.
v's
I am aware that this is probably a base Microstation issue, however, it is in Aecosim where this type of information and selection is most common
I'll request you to file a Service Request so that an Enhancement Request can be raised on this.
So yet again, Bentley remove functionality, then I have to request a mythical enhancement to restore the removed functionality. If by chance enough other people do the same it may possibly be restored at some point down the line, say 3/6/9/12months later, who knows.
There are enhancements I have filed years ago that have never seen the light of day and I have no idea if they are even considered.
Can kicked well down the road as usual.
This is not an enhancement but a restoration of necessary functionality
Hi Duncan,
Items/Explorer always listed the items based on the names of the Catalog Items and not Individual Section Names. This was the case in V8i too, and hence is not an instance of deprecated functionality.
An Enhancement can be raised for a request to incorporate this feature.
Tathagata
Apologies Tathagata, you are correct re Section Names. It would be a simple and extremely useful addition though.
I mainly came across this issue as U4 will not let me update the column catalog without updating the catalog section. ie, I am unable to deselect the section name to update a bunch of different columns at the same time as I could in V8. U4 will change the section and rotation of every column.
When changing Catalog Items it's simply picking up the DataGroup property values for the "destination" item - Section Name is one of those properties, and rotation is defined by the Family + Part which is the other property. If you have a workflow that requires you to change Catalog Items yet not take on that destination item's default property values, I would suggest filing an SR with those details so an Enhancement can be filed.
