Dears
i am using v8i ss5 microstation mechanical solution.
i am using the mdb files and text files for all mechanical categories like (pipes, elbows....etc) for control purpose (putting the BOQ Code inside the mdb file for a certain item).
iam now facing challenge for equipment like AHU i cant found the mdb file or txt file for such equipment.
kindly help me if there are a way for catch the AHU catalog in order to assign the BOQ in manufacture code field for example.
regards
i am sorry for this unclear words
AHU stand for Air Handling Unit
BOQ Stands For Bill of Quantities
MDB stands for Data base file
txt stands for text file
Could you add a new DataGroup property using a List data type instead? It doesn't look as though Ss5 included an \AHU_lib folder.
https://communities.bentley.com/products/building/building_analysis___design/w/building_analysis_and_design__wiki/12646/datagroup-definition-list-values
