Hi
Is there anyway to get the scale of the cut pattern from a callout to change with the scale of the drawing model scale? For instance, when I print a drawing in 1:200 and one in 1:10 on paper I want the distance of the prefabricated concretes crosshatch to measure around 20mm between lines on 1:10 and 400mm on 1:200.
Or is the distance between the lines always going to be the same, no matter the scale of the drawing model?
Regards,Robert
Hello Robert,
Please raise Service Request for your question, so that we can discussion it, in detail.
Regards,Aniruddh
