Grid Lines with Bubbles - Moving back to original locations
I am constantly having to redo the layout of the column bubbles on my plans.  they are set as I'd like them and then they tend to reset.  I do have the plans "Cach" updating when I open to work in a file but sometimes they stay as they were and then sometimes they don't
Parents Reply Children
  • Found the answer but not what I wanted to hear.  If the Reference file gets reset then you lose all your adjustments to  items like Grid dimensions, grid layout, doors and room names.  The but in the grid was it moved to the wrong spot but if you move it two more times it sticks
    Ustn since 1988
    SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64b
    Eric D. Milberger
    Architect + Master Planner + BIM
    Senior  Master Planner NASA - Marshall Space Flight Center
    The Milberger Architectural Group, llc
    Answer Verified By: Steve Cocchi
