What are diffences between "constraits" and PCS ?
We find almost simular functions like "parallel, perpendicular ....." except Contraits is more user friendly
now the question is it possible to integrate a "contraits" in aecosim with dataset "catalog editor" and replace paz file by contraits file ?
tanks
Hi Joel,
Yes, they can be used in AECOsim with the dataset catalog editor. However, these cannot be used for doors and windows.
Hope this helps.
Satadal
Hi Satadal,
yes, thank you
More information about this topic was discussed in this thread if you're interested: https://communities.bentley.com/products/building/building_analysis___design/f/aecosim-speedikon-forum/170424/creating-parametric-bim-objects/491449#491449
thanks ...
You're welcome!
