I found out that the default is a DWG file in layout space in new versions of AECOsim/Microstation. I also found out that the variable "MS_DWG_SINGLESHEET_AS_MODELSPACE" if modified to 1 will export DWGs with model space. However, i can not locate this variable in AECOsim V8 select series 6. Any idea?
Hi Yehia,
Yehia Elsayed said: in new versions of AECOsim/Microstation
Please always specify the version exactly! It's not clear what version is "new" for you.
Yehia Elsayed said:However, i can not locate this variable in AECOsim V8 select series 6.
I have no experience with this variable and have no ABD V8i installed, but after reading this wiki article I assume this variable does not exist by default and you have to create it.
With regards,
Jan
That looks about right, Jan. AECOsim Ss6 ran on MicroStation Ss4, so that wiki seems to fit the bill.
