DV'S Do Not Recognize Changes to Saved View
This used to work.
You create a DV that also creates a 2d plan where that DV is refereenced.  You annotate that Plan
Then things change and you add or remove reference files.  You "Save View" used for that DV
And the plans used to reflect the added reference file in my current case.
But now it does not and the only fix is to reattach that same DV that now knows the changes
The plan is now correct but all changes to the Grid and Rooms and Door Numbers have changed back to default
This used to work and does not now.  Checked on three different installations.
Wasting hours redoing work.
