Hello
How can I define Item Type so that others can useElement Templates to call it?
I try to put the file what i defined in C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\Example\WorkSets\MetroStation\Standards\Dgnlib,There is no way to make the model attribute by choosing Element Templates.
Thanks!
Please can you confirm which application and version you are working with; and which WorkSet you have active?
Item Types are accessible from DGNLIBs from MicroStation CONNECT Edition Update 11 and AECOsim Building Designer Update 4 (which includes MicroStation U11).
The DGNLIB must be in the correct DGNLIB folder for your active WorkSet.
Marc
Hi Marc
Application: MicroStation CONNECT Edition Update 11
Workspace: Example
Workset: MetroStation
Filename:SL_Level_MS.dgnlib
File location: C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\Example\WorkSets\MetroStation\Standards\Dgnlib
Set Active Templates: 填筑
Place SmartLine,there aren't Item Types in this line.
Thanks.
Hi Jack,
Please check if the element template association is turned on while the smart line is drawn.
Check this image below.
Best Regards,
RJ.
Answer Verified By: Marc Thomas
Thank you very much!
