Is there a "Paste in Place" function?...
...or should I just stop trying to use AECOSim like Revit?
Thanks in advance.
M
  • Hi Max, depends what you are trying to do.
    The copy tool will pick up a element or selection of elements by the point that you choose, this point can then be used to snap to the target location.
    Ctrl + C followed by Ctrl + V will offer to paste the element (or selection) by centre point of a bounding box that encloses the element(s).
    In AECOsim the Icon Lock tool box can be used to toggle ACS Plane and ACS Plane Snap Locks on/off to fix or free the placement plane.
    Another technique is copying through from a reference file.
    Feel free to ask for more suggestions if you have particular situations in mind.
    Marc
  • Another one.
    Use a tentative point to define the origin.
    Also possible via VBA. Maybe Marc or one of the other Bentley guys could do one?
