Hi!
How to select all Concrete Wall, Concrete Slab, Concrete Column, Concrete Beam in one DGN file using keyin?
You can use the explorer to select elements based on your requirements. If you want to select multiple element types, Ctrl+Select will work.
Please see the screenshot below:
Hope this helps.
Tathagata
Tathagata Saha said:You can use the explorer
The question was about using key-ins, not mouse...
Jan
Yes. Using key-ins.
I create C# programm for IPC mode of AECOSim. My programm send key-ins in automatic mode. namespace Bentley.IPC. contains this functional. This analog batch process for use in C#.
I'm interested in using key-in, not a mouse.
I'm trying to use selectby tools. For example, select only ConcreteWalls level.
selectby level ConcreteWalls; selectby execute
