Can anyone help me with this?
I have a laptop and two additional monitors. Recently, the laptop was upgraded and replaced and the operating software was changed to Windows 10.
Since that change the view settings are not being retained and at every start up the second screen is overlaid on the first.....some toolbars are as they were left, but those along the bottom revert to the first screen. The previous laptop was fine. Both laptops had the setting of laptop as screen 1, the main working monitors were 2 and 3 respectively, left to right.
My settings are to open two application windows and save settings on exit. It is extremely frustrating to find that this happens every day.
Any information or suggestions on the topic would be welcome.
Hi Steve.
Thanks for your response. This pointed me to several related articles, and I think I have discovered what may be the problem. Whilst I had created my own .upf file, having looked through the configuration files, the system appears to be pointing at the AECOsim default .upf file. I'll see if changing that affects the setup when I have a bit more time to look at it properly. Thanks again.
I'm glad that helped! Even if it was indirectly.
