How to compare models in AECOsim CONNECT?
Hi, is there a way to compare two models in AECOsim CONNECT? The objective is to see the differences between a model and an updated revision of it.
Thank you
  • One method is the Design History feature (covered in the help documents). Once enabled this allows changes to be displayed with colour coding and revisions to be compared.
    This occurs between revisions within a file not between different files.
    Comparison of different files could be accomplished using clash detection, comparing all elements or selections if specific areas are being evaluated.
    Marc
