Cut Solids issue in AECOsim
Good Day!
I facing some issues with the Cut Solids which was used for some element creations. The same has been checked in Navisworks Manage by importing an IFC file of that. I can see the curves/user cuts etc. in that file.
Attached below are the snippets that exactly showing the issues.
Image with out Cut solid
Image with All levels are turned on (Cut solids)
I would you appreciate for a prompt response to get rid off this issue in easiest way. Thank you very much.
Cheers,
Balaji G
