Hello. I know, there is new version (connect edition) in company. Is it possible to install two versions on one computer? and there will not any problem
CONNECT Edition can be installed alongside V8i.
However we recommend that you do not use both versions on the same project. While the DGN file format itself and most basic elements within a DGN do not change across versions, AECOsim Building Designer specific elements and Datasets do change to accommodate improved features and other changes, these are not backwards compatible.
Marc
Answer Verified By: Владислав Ахунджанов
