How to add Verify Part Tool to Quick Access Toolbar?
We use very often Verify Part Tool from Backstage, but it's very inconvenient to start it from Backstage area and
regularly I have to show some of my colleagues where to find this tool.
To shorten the start I want to add it to the Quick Access Toolbar but I can't find it in the Customize Quick Access Toolbar Menu.
Is it possible to add it to Quick Access Toolbar and where is the Tool hidden in the Customize Menu?
Thanks for your help.
Christian
  • Hi Christian,
    If you are using the CONNECT Edition you can simply type the name of the tool in the search option in the Ribbon bar and it will be listed in the dropdown list.
    Tathagata
  • Hi Tathagata,
    Sorry but I forgot to mention the version. It's CONNECT Edition U4.
    I know this possibility, but I like to add tools to the Quick Access Toolbar and my users like it too!
    It's the shortest way to start tools. just one click.
    Christian
  • Hi Christian,
    You could add a new button and assign the required keyin / description / icon.
    Cheers.
    Best Regards,
    RJ.
    Answer Verified By: Christian Mittermeier
