How to add Item to Element Template
MicroStation Update 11
I have created some Items in an Items dgnlib which makes them visible and usable by everyone, but how can I attach an Item to an element template so that the Item is attached to every element drawn using that element template.
When in the Element Template dgnlib I right mouse to add the Item, there is no Items to select from. I can see the Items in the Item Types dialog but nothing in the dropdown Add list.
What have I done wrong?
I have found that if the Items are stored in the element template dgnlib you can add them, is this where they should be located?
John.
