PCS v8i Help drawing Window Swing
I need to draw in pcs a "V" to show the swing of the window.
I must create a componet so I can attach a part to make it dashed
HELP
  • I'm not sure about the "v" aspect, but you can assign a part to a PCS solid:
    - Double-click on the applicable solid and switch to the Attributes tab.
    - Right-click and choose New
    - For families, use the attribute _TF_PARTFAMNAME and type in the appropriate family name
    - For parts, use the attribute _TF_PARTNAME and type in the appropriate part name
Reply
  • No I need d to create a "v" that shows up in the plan and rendering
    I have to place two lines or once line string from on hte sash
    Top left to middle right to bottom left
    I can do this but I could not attach a part.  I found I had to add the part desription in the attributes manually.
     MANUALLY seems a little backwards for 2009
    Ustn since 1988
    SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64b
    Eric D. Milberger
    Architect + Master Planner + BIM
    Senior  Master Planner NASA - Marshall Space Flight Center
    The Milberger Architectural Group, llc
