Structural Wall Export to ISM
We are starting to use the ISM exporter for our engineers to use in STAADPRO I believe.
We have a model with both Concrete walls, Floors, & steel frames. When we export we only get the steel members to export. We have been following the procedure out lined here  and you'll see in step 4 the ISM translator is picking up members, solids & walls.
My only thought is that the Slabs and walls aren't part of the structural catalog, in a test model i can insert concrete beams & columns, steel beams and columns and pile/foundations and they are picked up in the ISM translator.
I've added walls to the structural catalog with similar definitions as the architectural walls yet they still wont come though.
Is there something simple that i have missed? or is there a mapping file that needs to be updated.
Currently running AECOsim Connect Update 4
Any help would be greatly appreciated
Dave
