I am running through all our project design files and compressing them. I am having an issue with the odd file where abd crashes and I get the System Fault bad memory error.
On this particular file I have detached all the reference files and then reopened the file. I have noticed in the message bar and the bar at the bottom left files are being loaded that are no longer attached. Is this the standard behaviour of abd?
Hi Simon,
Could these be references attached to Drawing (possibly cached) or Sheet models?
Marc
Hi Marc
The file I am referring to in this case would be attached to a separate dgn file and then a drawing view created and cached. So would all the other 300 odd design files we have.
I do know that the files causing issues are mainly mechanical models and all have had geometry imported from either dwg, dxf, step etc.
FWIW, no, if all reference files were detached from a DGN file it would not be normal to see those files being loaded in the status bar. While reference attachments are stored as settings within the DGN, once detached those settings would be updated at least when closing the file and/or exiting the product. Did the DGN in question close normally after you detached those references?
