I am using AECOsim CONNECT Edition update 4.
Sometimes when activating the section callout, it appears in the bottom. I was expecting it on the top. How to I change this? I believe it is related to the way I creating the section. However, I would think there is a way to change this.
Thank you
Hi Juan,
For Section callouts that have one bubble, it is typically located at the first data point selected. So in your example you likely placed the callout in a bottom to top sequence.
Thank you Steve. But you are assuming that I created the section on another section view. What happens if you create the section in plan view?
It's no so much about the type of Model in which the callout is placed, but rather the placement point sequence. So even if placed directly in a Plan Model, if the two points used to place that Section callout were from bottom to top and then the direction towards the left, the bubble would be at the bottom.
