Hi
In v8i we've used the tool "cut solids by curves" to create penetrations in slabs, walls and structural framework. It seems it don't work any more. What tool should I use instead? I've found the "construct opening" which works for openings. But for eg. a slab recess it don't work.
Robert
Hi Robert,
I just made a small test case on one of the slab and it worked fine for me. Please go through and let me know if it helps you.
Warm Regards,
Subhamoy Kundu
Hi, thanks. Looks like it's the key-in "construct cut" that don't work, I needed to use " legacy construct cut".
Hi Subhamoy,
you are in active workflow AECOsim/left-up/, switch to Modeling and Modify/ Features/ CutSolid works with any problem
regards
Karol
continued....I am affraid this answer is for Robert :-)
Andrej
The dialog button DOES NOT WORK. the work around is to type what you need into SEARCH and select from there. I have reported this a couple times
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
