Any word on when this will likely be available?
just in time for 2020 no doubt!!
Hi Duncan,
Not that I've heard... but I will check.
Thanks Steve
I received this response to my SR regarding this "The direct Revit iModel plugin appears to be dead. "iModel bridges" are the means to transfer files from Revit to iModel henceforth".
That worries me as we need to use Revit 2019 for some current projects and no one here knows anything about I-model bridges and there is not much documentation out there as to how to implement it...
Mark
OpenRoads Designer 2022 R1 (10.11) | Microstation CE Update 17.2 | ProjectWise CE 3.4
Mark Shamoun said:I-model bridges
Re-branding?
Hopefully, the Revit to imodel export would be improved. Interesting aside that you would get better results if you export to Rhino first via DWG for architectural elements.
Bentley has accumulated a number of Revit export tools (imodel exporter, ISM publisher, RFA-Interpreter) in addition to the dwg and the 'Kind of OK' IFC tools. Amazing how negative people are about Bentley products!
If the new bridge app will consolidate things, it would be a step forward.
Looks like a completely new implementation for i-model 2.0. Sounds great, but how do we use it now for project delivery?
https://imodeljs.github.io/iModelJs-docs-output/learning/imodel-bridges/
