Why doesn't AECOsim see all of the Windows TrueType fonts.
There are 9 Arial fonts in Windows 10, but AECOsim only lists 2. Arial Black and Arial Narrow.
How do I get AECOsim to see the other fonts ?
Michael
Windows 10
AECOsim SS6
AECOsim CONNECT U4
Hi Micky,
Have you tried to copy the same in '$(_USTN_SYSTEMROOT)fonts\' ? The same is available in MS_FONTPATH variable
Warm Regards,
Subhamoy Kundu
I managed to see Arial again
I had a legacy .rsc font file that took priority in the font list.
Once I removed this, Arial appeared in the font list.
I now have 3 Arial fonts listed..
I tried copying the fonts to the \fonts directory with no luck. AECOsim still can't see the additional fonts.
Just to be sure... you are going down the list of fonts past the "@" series, correct?
On my system these are the same Arial fonts I see outside of AECOsim; e.g., Word, Outlook, etc..
Yes I am going down the list as you described.
Now that I have removed the .rsc file, I now see the same fonts as Word.
