I would like to export my file to IFC, the contents of my file are only some paremetrics cells (cube and cylinder)
I've no probleme when I export directly to IFC, but when same file is on reference IFC is EMPTY !!!
Iook my screenshoots
1 wall
1 duct
4 parametrics cells
IFC = OK
parametrics cells in reference
IFC
1 Wall
1 Duct
4 parametrics cells Are missing !!!
to be complete my datagroup catalogue
thanks for your feed back
Hi, I would like to follow up on this question because I also had the same question on version update7.It has only happened on parametric cell. Did you have any solution? In my case, transfers all parametric cell become common cell... (But, this way is not a good method.)Thanks Lynn
