Hi Guys,
Using v8i ss6, I have created bespoke catalogue and assigned data to graphical elements, I have been using this successfully for sometime now, but my latest model creates an error; When publishing to i model the data has duplicated on certain elements.
The native file shows single set of data only, the duplication occurs in the published i dgn file only!
Does anyone have any experience in the doubling up of data when publishing and any method of preventing/fixing this?
Thanks in advance.
Stephen
could you share some screen shots ans the possibly a copy of an imodel
Brenden Roche
Applications Engineer
Bentley Systems, Manchester UK
Brendan
Attached snap shots of native and idgn with element info listed for your review.
Hi Stephen,
It almost looks as though the data is being published from both the dataset and project level. Where are those schema (xsd files) stored?
Steve
My xsd file is at
Again duplication only occurs on some elements within published model not all elements.
Thanks. So that is the only location where the custom XSD file is stored, correct?
When the duplication occurs is it only for those specific elements that use the custom schema? And if so, are you saying that even within a single DGN file, some of those custom elements come across as expected in the resulting iModel and others (of the same type) do not?
