I'm trying automate the exporting of ifc files and would like to either be able to nominate the export directory from the keyin.
mdl load TFIFC $ IFCOUT * c:0
Alternatively if I can use -wabatchprocess -i and -wc my Startup config file will define TFDIR_IFC. The below doesn't work
Echo Starting Start /wait "batch" CMD /c AECOsimBuildingDesigner.exe -wabatchprocess "-iF:\751EW-ST-IFC-TEST.bprc" "-wcF:\FMG_V2_Startup.cfg" Echo Done
Hello Simon,
We will check it and let you know.
Regards,Aniruddh
This line has appeared in the OBD U5 dataset example project.
# IFC: IFC_EXP_OUT Specifies the destination directory for exported IFC files IFC_EXP_OUT = $(_USTN_OUT)IFC/
Hi Duncan,
That was in the U4 WorkSet.cfg as well so I'm guessing that we did not include it in the list of new variables published with the initial CE release.
IFC_EXP_OUT is used in addition to and overrides TFDIR_IFC to enable exports to be stored in a separate location to imports.
Hi Simon,
Assuming this is CONNECT Edition, please try defining IFC_EXP_OUT in your configuration. If it is V8i, this is not relevant.
Marc
Hi Marc
I am already aware that this can be done via a configuration variable, I was wanting to be able to pass in a path from a keyin command
