Hi
I've got big problems with my callouts. First, let me explain our workflow. We create a file per floor and building in which we place 3D-elements. We reference all those models into 2 separate models, lets call them callout_plan and callout_section. One for plan-callouts and one for section callouts. Reason for this is that these files often get really slow when there are lots of callouts. We then create a drawing model from the seed drawing modeln, and not via the crate drawing option for callouts. We then reference the callout to the drawing model, set to cached. At least earlier the pattern didn't work in dynamic view, and the files get quite slow if the reference is in dynamic view.
Now I have a couple of problems.
1. Lets say I've drawn up one building and created callouts and models for that one. I then draw another builing beside it, and I want that in the same drawing model as I've already created. When I expand the callout in my callout_plan model to cover the new building. This expansion often don't work as it should. The cutlines are not the same in the callout_plan as it is in the drawing file that holds the calllout reference. I think I get problem when I reference a new model into the callout_plan after creating the callout.
2. I also have problem with seting display off for sertain models in sertain callouts. Seems it's not pushed trough to the drawing model, even though I update the reference from the saved view and so on.
3. Lets say I place the plans first, and then sections. The section will show the correct label for the plan callout, (but not if I change number or something like that) and the section callout's label won't say anything on my plan drawing. I've tried update all models, but seems it don't work.
Robert
Hi Robert,Which version of ABD( now known as OpenBuilding Designer) are you using?Can you please attach a few screen grabs or a short video clip to illustrate your problem?
Hi. Update 5. It's a bit hard to send you a video. 1 and 2 you should be able to replicate, number 3 too, but I could send you my files it that would help?
Hello,I will have a look one more time. You can upload your files at this link.
