I have a network drive for my workspaces and worksets. In each case I have added BB_FloorMaster.Dgnlib to the workset/standards folder based on the UK Template. I cannot add a building or floors to the floor manager and consistently get the message failed to check out the BB_FloorMaster.Dgnlib. Any ideas?
Hi Bill,
Based on the "failed to check" message are you also using ProjectWise? If so, which versions of AECOsim and PW?
Also, is this a recent issue or has it always happened in your current configuration?
OK, that is interesting... is the message you're getting literally "failed to check out the BB_FloorMaster.Dgnlib"?
Also, was the file carried over from a previous version, and if so, which one?
