Hi
I've created a callout from a design file, and placed it in a drawing file. When I try to place annotations (purple lines) in the drawing file, they get placed behind the callout (slabs and wall) for the grey filled area.
I thought it could have something to do with the update sequence, but as you see my active file is on top.
Running Openbuildings (update 5).
Robert
Hello Robert,Is it a general problem that you are facing with every file? I will investigate and share my findings on this.
Yes, it is. Both I and my colleagues have the same problem.
Robert,
Could you check the display by moving the active file to the last in the reference update sequence?
Cheers.
RJ.
Answer Verified By: Robert Högberg
Aha, that works. I thought it was the highest priority should stay on top? I can see there are MS_REF_MASTERFILELAST_xxx variables. What value should they have for this to work properly?
The values for those variable are defined by default according to the model types, design=0 drawing=1 and sheet=1.
Clicking the default button in the update sequence window would position the active model in the appropriate sequence based on these variables.
Answer Verified By: Steve Cocchi
