No idea why this is happening, but it's very annoying. I have placed a number of members with Automatic Coping turned off. I want to place another member and on a function key use the keyin 'match element fromcursor' to match the member properties. The thing is, doing this turns Automatic Coping back on. Can't work out why.
Surely this isn't WAD.
Did you try using the 'Match Attribute Tool' from the ribbon?
Just for a bit more feedback, Match Element Properties from the dialog does the same thing.
Which 'Match Attribute' tool are you referring to? Not really looking for more clicks and this keyin has worked fine until now.
