Trouble Shooting Custom Line Styles
An element 400 mm long should be repeated continuously, one after the other with no gaps. The element is turned into a Point component and the Stroke pattern designed as: Shift/Distance/0.0, Repetitions/Unlimited, Single Segment NOT ticked, Length/Fixed: 400 mm, Stroke Type/Dash, Invert at/None, Corners/Break, Width/None…
Problem: The Point component shows up when activating this line style, at the start point and at every data point placed, but not continuously. When inspecting Rail road line style, the ties just repeat at a certain distance until you end the Smartline. I have tried to tick Origin, Vertex, End but nothing happens. Any idea?
Ingemar
