Hello all,
I am new to bentley products and I was wondering if there is any book for mastering OpenBuildings designer , while am searching i found a book "Practical Architectural Modelling With AECOsim Building Designer" the problem is that this book is for older versions , also most of tutorials i watched are either basic or using older versions , any hint is appreciated
Hi Osama,
You can try our Learn Server at learn.bentley.com. There are many learning paths that you can choose from. There are also Special Interest Group Seminars whose recordings are available there. You can watch those as well.
HTH
Satadal.
