Is there a clear explanation of how to work with geometry maps?
Hi Bill,
You're not seeing this?
Hi Steve, Yes I am seeing that. I don't understand what cells I need to make to work as geometry maps. If I try to use a existing cell from the UK dataset such as RANRBL from the Annotation.cel library I get a message saying 'cannot use cell' Can you explain how the cells should be made and whether they can just go in the standards/cell location. Best regards, Bill
Just to cover the basics first, the cells you are picking are 2D?
FWIW, I don't see a cell named RANRBL in annotation.cel under the folder ..\Configuration\Datasets\Dataset_UK\Cell\.
The delivered geometry maps (for CONNECT Edition) are in C:\ProgramData\Bentley\connectsharedcontent\cell.
There are two libraries
GeometryMaps_Clean.cel
GeometryMaps_Sketchy.cel
The path to these is included in the MS_CELL variable so U5 should be able to see these.
If you wish to create customised cells I suggest:
Marc
No sign of any such directories of content. When would they have been installed?
