I have exported some elements from ABD V8i SS4 as STP and then I imported the STP in autocad/ABD again to check whether I got them correct, found that all elements are there but they all are on 0,0,0, imported items are lying on one another.... Is there any way I can export STP without change in elements locations...?
This is not supposed to behave like this, ideally.
Can you upload the file so that we can have a look?
I once saw a similar post some time ago so my memory might be bad. The geometry in the orginial DGN file was a long way from the file origin at 0,0,0. Please copy the file move the geometry to near 0,0,0 and then try the export again.
Brenden Roche
Applications Engineer
Bentley Systems, Manchester UK
Please check the variable MS_ROSEDB this should be pointing to the rose folder on your c drive. failing that could you file service ticket,adding the file and the log file please.
HTH
