In Building design there is a icon called PLACE TRUSSES , while clicking that option I am get getting a issue that Aecosim has been stopped working. How to sort out this issue ?
Which version of the software are you using?
Version 10.05.00.49
I checked this at my end in OpenBuildings Designer U5 (10.05.00.049) and faced no problems while placing a steel truss. Are you facing a crash while working with any other tool? Or is this limited just to the 'Place Truss' tool only?
I am only facing a crash for Place Truss tools only .Other tools are working Properly.
I had a similar issue with OBD U5.
I work with Dataset_NM and I had to add the shape definiton file AU_OneSteel.xml to variable STRUCTURAL_SHAPES
to prevent a crash only if I tried to place a beam.
There is a sturctural shape defined in the standard configuration of Dataset_NM which is stored in AU_OneSteel.xml
and it seems it causes a crash if this shape file definiton can't be found for the beam tool.
Answer Verified By: Pranay Vijaykumar
