How to calculate the volume of material for a given structure in aecosim ?? For example A concrete structure is modelled . I want to calculate the volume of concrete in aecosim . Is there any solution for this??
There are two ways of doing this.
You can use the "Schedules" tool in the Reports section under "Data/Reporting" tab.
Other option would be to use Structural Quantity Spreadsheet from the same section.
You can use anyone of these based on your requirements.
Answer Verified By: Marc Thomas
OK Thank you sir. I got your point.
Don't forget to substract your rebar :-)
Oh sure sir . Thank you for your information
