Where can I find the resolved issue list for U5? or any other version of OBD?
Best regards,
Tuan Le
Hi Tuan,
I would request you to go through the below mentioned Announcement Page once.
OpenBuildings Designer CONNECT Edition, Update 5 (v10.05.00.49)
Over there the highlighted features are mentioned which includes some of the resolved issues.
Warm Regards,
Subhamoy Kundu
Hi Subhamoy,
So there's no specific resolve issue list supplied for OBD CE going forward, with the defect/tr/cr number and description? Microstation CE has 1 for every update. I'm pretty sure AECOSim V8i used to provide the same list at one stage, up to at least SS3 if I remember correctly. But now CE isn't going to provide any specifics of what has been fixed for each update, is that correct?
Essentially, I'm looking for something like this, but for OBD U5
ftp://ftp.bentley.com/pub/.../help/AECOsimbuildingdesigner/081109376en/html/buildingdesigner/resolvedissues.htm
I don't believe we've done anything like that since SELECTseries3 which was essentially the first version of AECOsim as a product (coming from the previous separate products before). AFAIK it would be nice to have but the overhead prevents it. Was there anything particular you were looking for?
Also, not that I've had reason to look before now, but where did you find the equivalent for MicroStation CONNECT Edition?
Hi Steve,
You can see the resolved issue list for MS CE published in the wiki page below. From what I can see it may not be the full list, but it certainly helps with evaluating upgrades.
https://communities.bentley.com/products/microstation/w/microstation__wiki/27351/faq---microstation
