HiI have .dgn file with only one model (work in OpenBuilding Connect Edition and AECOSim)But when I open Batch Process dialog and add active file, I have two models. Why?I attach work file to my messege.7002.50UKC-CDZ0025_B01.dgnThanks
Have you created the sheet file in a separate .dgn while creating DV ? or Did you create a saved view and place it on sheet file ?
What is the workflow that you have used ?
Saved view and sheet file are created separately. Tried to use different workflow - no results
I performed a test case in ABD Update 4, where I've extracted the sheet as a separate .dgn while creating the DV. It seems fine for me.
The screengrabs that you've attached, are they taken from ABD UP4 or OBD U5 ?
