Is there any setting to make a merged DV to retain the information relating to its original 3D elements, like DEM? At the moment when I merged a DV, all elements are blown to bits like what you'd get from a visible edge extraction. Where as with DEM, each 3D element will be converted each individual cell.
Best regards,
Tuan Le
A Dynamic View creates new elements when presenting the 2D representation, so merging those is just merging those new elements.
What outcome are you seeking?
Marc
Hi Marc,
Attached is a test file from DEM in SS6 default Building_AU example. Is there any way I can replicate the same output with DV, as in each 3D structural element is converted to individuals cells, not just lines. You can even query part and family data from those 2D cells. We need to replicate that level of detail with DV.
8400.test_ss6.dgn
Just wondering if there's any update on this subject?
SR 7000926085 raised.
I can please get an update on this SR? The last response I got was on the 13th.
