I had to export a sheet from Revit to DGN. This sheet has several references that are images. When I open the exported DGN file the Raster Manager shows everything as undefined. I use to be able to right click and select File Name from the flyout and change the location. For some reason this DGN is saying it is read only and File Name will not let me change.
How in the world do I get it to allow me to change the path or become readable so File Name works as I remember it?
I tried to double click the check mark beside the image in Raster Manager, In the properties under Image change the Read Only to False and nothing worked.
Thank you for the help
When you say that you were able to right click and select File Name earlier, in which version of OpenBuildings Designer were you able to do so? Also, in which version are you not being able to do the same now?
Besides, are both the scenarios occurring in DGNs coming from the same Revit version?
Tathagata,
I had update 4 and just installed 5. Same version of Revit to DGN conversion on same project. Version 5 I can't right click and get File Name to allow for a folder selection. It show read only.
I found the problem. When this file was exported from Revit it created a second reference file that had all the images loaded into it. I had to open that reference file and repath the images and then they appeared correctly.
Thank you for the help.
Answer Verified By: Steve Cocchi
Good to know the issue has been resolved
