When Cutting a building section - we define a cut plan and a rear and front plane are displayed
Wheat we are creating is a section that shows only items 10' beyond the cut - THUS THE REAR DESIGN PLANE
What we see is a Building Section that ignores the REAR PLAN and EVERYTHING beyond the cut
This worked fine in ABD, and appears to have stopped working in the Connect Version
How do I create the proper section that does not become an SECTION-ELEVATION
FYI - I TRIED TO LOG THIS INTO THE CONNECTION CLIENT BUT THE THIS PORTION OF THE SYSTEM IS DOWN.
Hi Eric,
Can you please share a few screenshots to elaborate on this?
Not necessary - I want to cut a section in the middle of my building but only see back 2' - instead the bak clip is ignored and I see everything beyond the clip. Now I have a section elevation . I jsut wast a section and not see but 2' of depth beyond the section. I could do this prior to connect.
Ustn since 1988SS4 - i7-3.45Ghz-16 Gb-250/1Tb/1Tb-Win8.1-64bEric D. MilbergerArchitect + Master Planner + BIMSenior Master Planner NASA - Marshall Space Flight CenterThe Milberger Architectural Group, llc
The reason Tathagata asked for a screen shot is that without one, we can only assume your Clip Volume's edit handle(s) are not cropped. But that behavior has always been the case for Clip Volumes - the arrow symbol vs. the "plug".
