i tried installing open building designer and couldnt find it listed in my apps
have i installed it wrongly?
HI David,
it's recommended to always specify what product version do you use, also to mention Windows version maybe helpful.
When using AECOsim Bulding DEsigner and OpenBuildings Designer, it's important to start the product in a correct mode: There should be more "OpenBuildings icons" available, where "the right one" is OpenBuildings Designer CONNECT Edition. But maybe you started the product using OpenBuildings MicroStation CONNECT Edition shortcut that starts the product in "MicroStation mode" when building tools are not available?
With regards,
Jan
[AUTOMATED MESSAGE; if there is a link below, please follow that if you wish to respond to this Communities message.]
RE: installation
Did this answer your question?
Verify it as the answer or Reject it as the answer
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here.Flag this post as spam/abuse.
David Turner
MEP 3D coordination & BIM Technician
Rail Projects
