As per the Guide I Have Follwed Each Step, But It's Not Working.
See Below Image
Hi Nagarajan,
It seems to be working OK here in SS6. If you choose Help > About what is the build number you are using, and, which dataset?
No Steve, In my system this command is not working. i don't know why.
I understand, but I still need to know the specific version and dataset you are using. If we cannot reproduce it here then there is some difference we need to account.for,
Version V8i (Select series 6), UK Dataset
Thanks for confirming. The video below shows the type of results you should be seeing when using the UK dataset in Ss6. Can you try these same default settings?
