In Microstation V8 i used short keys for the most common tools.
e.g. 3,1 = copy 3,2 = move 5,1 = change attributes 3,9 move parallel etc
is there a way to revert the short keys on the connect edition back to this without any differences?
Hi George,These shortcuts can be activated by enabling position mapping in Microstation CONNECT edition.Please see this wiki on how to enable position mapping in Microstation CONNECT.Hope this helps.RegardsAditya
I did this, however the short keys were not the same, for example for move i have to press Q,2,1 instead of 3,2.
i memorized all the short keys so i don't want them to be any different. is this possible?
